Hallo,
gibt es in XnView MP die Möglichkeit die Symbolleisten zu fixieren?
Wenn ja, wo?
Grüße
Jürgen
Symbolleisten fixieren
Re: Symbolleisten fixieren
sorry but what do you means?
- Forum Librarian
I think Heiopei_64 would like to lock the toolbars in position by hiding the handle/gripper to prevent them from being moved by mistake.
PS:
https://www.stackoverflow.com/questions/37987116/how-to-lock-all-toolbars-via-menu-in-qt#37988390 wrote:Here is an example of how you can achieve it. First, add a QAction and a QMenu; also, declare all your toolbars private
https://www.stackoverflow.com/questions/37987116/how-to-lock-all-toolbars-via-menu-in-qt#71129174 wrote: One common example with flexible lock options
