Is it possible to increase the maximum number of image tabs? [Solved]
I found that the current version of XnView MP only allows viewing 100 photos at the same time (open 100 image tabs). Is it possible to manually config it to 200~300 image tabs, since I have large RAM on my PC? Thank you
Re: Is it possible to increase the maximum number of image tabs?
In XnView's settings (Tools > Settings | Interface | Tabs) you can set the maximum number of view tabs. By default it is set to 99 but you can increase that value as desired.
oh! thank you. problem solved.
Good. Thank you for your reporting back, stone666.
