1.0 and later: on MacOS: photos not scrolling with mouse and keyboard
yert
Post by yert »
Subject: 1.0 and later:: photos not scrolling with mouse and keyboard
XnView: MP 1.0 - 64-bit
OS: MacOSX 10.13.6
XnView not listing the photos when pushing ⬅️,➡️, "Page down", Page Up key and scrolling mouse wheel. Scrolling only tab miniture
Effect: not reation on hardware buttons
1. Browse a folder A with four image files (JPEG format).
2. Select first image file.
3. Open fullscreen (view) using F11 key.
4. Press ➡️, "Page down" to navigate to the next image several times
5. Next this bug can reprodeced and without fullscreen mode.
Actual behaviour (bug): not reation on hardware buttons
Expected behaviour: No crash, next image is displayed.
Re: 1.0 and earlier on MacOS: photos not scrolling with mouse and keyboard
yert wrote: Fri Jul 01, 2022 4:58 pm 1. Browse a folder A with four image files (JPEG format).
you quit here the fullscreen by ESC?
yert
Post by yert »
xnview wrote: Tue Jul 19, 2022 12:00 pm you quit here the fullscreen by ESC?
yes, but in fullscreen mode photos without more ado not scrolling by ➡️⬅️
sorry but i don't understand
yert
Post by yert »
yert wrote: Fri Jul 01, 2022 4:58 pm 5. Next this bug can reprodeced and without fullscreen mode.
1,6,2 version now 5. fixed but
Subject: 1.0 and earlier: photos not scrolling with mouse and keyboard in full screen mode
XnView: MP 1.0 - 1.6.2 64-bit
OS: MacOSX 10.13.6
1. Open image file from Finder (JPEG format or CR3 for example) or from xnview
2. Open fullscreen mode
3. Press ➡️, "Page down" to navigate to the next image several times. IF press more quikle XNview start scrolling files
xnview wrote: Thu Jul 21, 2022 12:33 pm sorry but i don't understand
I have made the video to understand what I mean
http://www.mediafire.com/file/syxh1k0p6 ... 211836.mp4
ok, i understand now. Another user had the same problem, but i'm not able to reproduce... Could you send me your xnview.ini?
yert
Post by yert »
xnview wrote: Sat Nov 25, 2023 7:33 am ok, i understand now. Another user had the same problem, but i'm not able to reproduce... Could you send me your xnview.ini?
I'm attaching it, thanks
you have not this problem with 0.99.5? I can't reproduce with your ini. Is it a MacBook or iMac? With attached screen? You seems to have 3 screens?
yert
Post by yert »
xnview wrote: Sun Nov 26, 2023 10:36 am you have not this problem with 0.99.5? I can't reproduce with your ini. Is it a MacBook or iMac? With attached screen? You seems to have 3 screens?
I have a problem with all versions :) and i always regually update it, I hope somewhen the bug will be defeated (now 1.6.2)
iMac iMac14,2 Intel Core i7 3,5 GHz 256 КБ L3: 8 МБ 16 ГБ Nvidea GTX 960 4095Mb
I have 3 monitors. It was quite cheaper than 1 very professional display :)
yert wrote: Mon Nov 27, 2023 1:07 pm iMac iMac14,2 Intel Core i7 3,5 GHz 256 КБ L3: 8 МБ 16 ГБ Nvidea GTX 960 4095Mb
If you have only the main monitor, do you reproduce?
yert
Post by yert »
xnview wrote: Fri Dec 01, 2023 7:44 am If you have only the main monitor, do you reproduce?
the same with one display
and with a clean .ini? (make a backup)
yert
Post by yert »
xnview wrote: Mon Dec 04, 2023 12:17 pm and with a clean .ini? (make a backup)
no changes
https://www.mediafire.com/file/ka9gqjyx ... 2.mp4/file
really strange. Do you have same problem when using fullscreen from browser and fullscreen in image tab?
yert
Post by yert »
no any problem in firefox full screen and mac image tab in fullscreen mode all working as expecting, only xnview not :(
