I can't see any differences on my TFT when using high quality zoom, except that high quality zoom is much slower.
Do other users see any differences in this option?
High Zoom quality - what's the difference?
XNView 1.91.5
Windows XP SP3
Windows XP SP3
Re: High Zoom quality - what's the difference?
The High quality thumbnails are rendered using a high quality resize algorithm (Lanczos, perhaps). If you set this option, make sure you clean the cache - thumbnails which are in the cache already, won't be recreated and you won't see any difference.klumy wrote:I can't see any differences on my TFT when using high quality zoom, except that high quality zoom is much slower.
