Draw module: Cannot use Eyedropper because of cursor
m.Th.
Post by m.Th. »
Steps:
1. Dbl-click on a image to open it in editor
2. Shift+D to open Draw module.
3. Click on Eyedropper.
Expected: The cursor should change.
Actual: The cursor is changed but the result is „garbage” - it cannot be used.
m. Th.
Re: Draw module: Cannot use Eyedropper because of cursor
I've just tried to reproduce the problem but Eyedropper works fine for me: X and Y position and colour value (decimal and hexadezimal) are displayed. What do you mean with "garbage"?
Note: Only irritating thing for me that I found is that 0,0 coordinate is top left of the picture and most top left pixel has coordinate has 0,0. I verified with Corel PhotoPaint and it's the same there. Looks like I've worked with Corel Draw too often, coordinate system in Corel Draw is different but Corel Draw isn't a bitmap/pixel image viewer so it's comparing apples and oranges.
m.Th.
Post by m.Th. »
helmut wrote: Sat Jul 09, 2022 8:48 am I've just tried to reproduce the problem but Eyedropper works fine for me: X and Y position and colour value (decimal and hexadezimal) are displayed. What do you mean with "garbage"?
The shape of cursor isn't displayed correctly. See the following picture: (the „cursor” is at the end of the coffe arrow)
m. Th.
I cannot reproduce this issue (Intel UHD Graphics 630 @ Intel Core i7-9750H), …
… but I found this:
PS: Good to have you posting again, m.Th. (-:
m.Th.: Thanks for the screenshot - a real camera shot of the screen. ;-) Sounds much very like the QT problem that XnTriq found.
XnTriq wrote: Sat Jul 09, 2022 10:15 pmPS: Good to have you posting again, m.Th. (-:
Right, good to that you (m.Th.) are around, again. Haven't seen budz45, Drahken, ckv, oops66, and some more for a while...
