XnViewMP abnormal color rendering
sybarix
Post by sybarix »
Color rendering in XnViewMP seems to be different from other programs. Notably, different what what I edited. The left is how it should look like, and the right is XnViewMP. XnViewMP seems significantly more contrasty than intended, and with a reddish cast. Custom ICC profiles are not used. Any ideas? Thanks.
Re: XnViewMP abnormal color rendering
Do you use a color profile on the Mac?
sybarix
Post by sybarix »
No I don't. I also tried changing true tone/night shift just in case, but those are global settings as expected and do not result in the side-by-side differences seen.
i means in the Mac's display settings
sybarix
Post by sybarix »
Yes, it's on default settings
you need to choose same color profile in Settings>Icc
sybarix
Post by sybarix »
Doesn't seem to work unfortunately.
could you send a sample file? which color profile do you have?
sybarix
Post by sybarix »
The image seems too large to attach here and the .icc file can't seem to be attached either. I've uploaded both to dropbox at the following link:
https://www.dropbox.com/sh/4j7xp175l6mq ... iEz3a?dl=0
The .icc profile seems to be the default one used in my M1 Mac 14".
i've used your profile, and the display seems ok
sybarix
Post by sybarix »
If not the profile, any ideas on what might be the issue? Only seems to happen in XnViewMP for some reason. Opening it in the browser or in mac preview shows the image as it was edited.
could you send me a screenshot of settings>ICC?
sybarix
Post by sybarix »
in the second and third panel, choose sRGB
sybarix
Post by sybarix »
