Regarding this option. Tools > Settings > View - Camera RAW = Full Size.
I set this option to Embedded Preview for the best speed, and when i view full screen i want to be able to load for certain images as Full Size.
Would be nice to have a hotkey e.g. "A" that upon pressing will swap Embedded Preview for Full Size view for currently open image.
Hotkey to show Full Size image for RAW files
FKCapitalism
FKCapitalism2
Re: Hotkey to show Full Size image for RAW files.
Could you re-consider this feature sometimes its necessary for certain files only and changing the option trough the menus every time is not ideal.FKCapitalism wrote: Sun Jul 10, 2022 12:44 pmWould be nice to have a hotkey e.g. "A" that upon pressing will swap Embedded Preview for Full Size view for currently open image.
e.g. there is are bugs with DNG with panorama generated in Lightroom it only embeds JPG preview of 256x256 when browsing panoramas among normal DNG's its faster to use hotkey and don't go trough the menu and then switch back to show regular embedded preview for speed.
Please see FastStone Image Viewer they have this feature when press hotkey "A" it interactively loads RAW image instead of embedded preview.
Last edited by FKCapitalism2 on Wed Mar 04, 2026 7:17 pm, edited 3 times in total.
