Under Settings > Catalog > Tab: Catalog
I see drives and folders showing up that I do -not- want. I only what specific folders.
under tab: Excluded/included I can not 'manually' add a drive letter, like: X:\
I believe the drive should be 'detected', i.e. I should browse/select the drive.
OTOH such drive letters can be of external USB drives or even from encrypted container drive (like the ones from Veracrypt)
Those drives are not available. I should power on the usb drives and/or mount encrypted drives, so I can select them.
Most of the time are not available.
Can this not be set in some .ini file or so?
Like: exclude X:\ Y:\ or so?
Thanks.
How to manually add drives to be excluded?
Re: How to manually add drives to be excluded?
you can choose a drive in Settings>Catalog>Exluded
