Save should be available for unsaved images
fabjx
Post by fabjx »
When editing an unsaved image (created, for example, by importing the clipboard) in XnView MP, the "Save" menu and Ctrl+S shortcut should be available. In this situation they would just have the same exact effect as the "Save as..." option.
This is the expected behaviour because it is common to most Windows applications when editing new files, and would be useful because the universal CTRL+S is much more intuitive and easy to remember than Ctrl+Shift+S (which varies a bit between different software).
I've only noticed this today using 1.0 and haven't checked if this was different in older versions.
Thanks for your attention and your incredible work in XnView* applications.
