Image Size
JohnL
Image Size
Post by JohnL »
Hi, I am a newbie who has just found XnView and so far like what I see.
However I am looking for a facility to view an image at actual size and cannot find how to do this. Am I missing something or does this feature not exist?
regards JohnL
Exactly ?
:) Hello, my welcome aboard !
¤ What do you mean exactly ? You can adjust the displayed image-size at will according to the current window of XnView. There are a lot of menu-entries and options to perform this; please, just give a glance in the “View” menu >> “Auto image size”, and too in the Options >> View, I'm pretty sure that your happiness is there ! :)
:mrgreen: Kind regards,
Drahken
Post by Drahken »
I think that perhaps he means to view it at actual print size, taking DPI into account?
JohnL
Post by JohnL »
''. . . I think that perhaps he means to view it at actual print size, taking DPI into account? . . ''
absolutely . whatever my pixel count/size I wish to click a button and see the image automaticaly in that size. at present I cannot see that function - but would like to :)
JohnL
Drahken
Post by Drahken »
That would be a nice feature. Unfortunately, I've never heard of any image viewer that has it.
JohnL
Post by JohnL »
just to add, I appreciate the options> view variations and I take it the '' no fit '' option is an 'actual size' of the image as I would like it. however I expect most view an image in 'fit image to window' but a button with actual size/ no fit would allow simple toggling between screens and be a lot quicker to use than flying up and down drop down screens.
just imho but hope something could be done
regards JohnL
Drahken
Post by Drahken »
The "no fit" and "fit window to image" options show the image at 100% zoom, but not at actual, realworld size. (ie They'll show the image at it's full 500x500 pixels instead of scaling it down to 250x250 pixels, but it won't show it at 3 inches or 20 centimeters or whatever.)
JohnL
Post by JohnL »
Hi Drahken
. . . . That would be a nice feature. Unfortunately, I've never heard of any image viewer that has it.
mmm, . . try ACDSee, Faststone, Breezebrowser, iView . . . . etc etc :)
I also think you may find the '' "no fit" is an actual size but I would like confirmation and ask if its possible to add some kind of quick link without having to go to drop down windows.
JohnL
Print-size
:) Hello !
- Maybe just adding "Units" in the options for the size-features could do the trick ?
- Or else, an option reachable from a menu : "Printed size", with the choice of geometrical units too ? And¦or standard page-formats (A3, A4…) ?
Xyzzy
Post by Xyzzy »
JohnL wrote:I also think you may find the '' "no fit" is an actual size
It's not. It's pixel-exact size: one pixel of image fits one pixel of screen.
If you want something like your demand, go to Print window (File>Print) and you can play there. You can see there how image fits some area taking into account different DPIs.
BTW, if somebody would like to see, at least approximately, how the picture looks printed, XnView would have to support _at least_ color management in the FIRST place, not talking about support for differrent RIPs (raster image processor).
Color management would be welcomed BTW.
Anyway, adding to Zoom menu 'Use image DPI' should do the trick. There is already 'Set Selection size', so determining size based on image/monitor DPI is already there- just resize image instead of selection.
X.
JohnL
Post by JohnL »
Thanks Xyzzy, but - '' If you want something like your demand, go to Print window (File>Print) and you can play there. You can see there how image fits some area taking into account different DPIs ''. I dont think that addresses my comment - '' whatever my pixel count/size I wish to click a button and see the image automaticaly in that size. at present I cannot see that function - but would like to ''
'' Anyway, adding to Zoom menu 'Use image DPI' should do the trick. There is already 'Set Selection size', so determining size based on image/monitor DPI is already there- just resize image instead of selection. '' - I presume you are adding that as a suggestion to XnView as a way of addressing my request.
'' BTW, if somebody would like to see, at least approximately, how the picture looks printed, XnView would have to support _at least_ color management in the FIRST place, not talking about support for differrent RIPs (raster image processor).
'' Woah, nice but lets keep it simple eh :D
thanks for the comments anyway
JohnL
Olivier_G
Re: Image Size
Post by Olivier_G »
JohnL wrote:view an image at actual size
What do you mean exactly by "actual size"?
(I have read the many responses, but I still find them not clear, overall)
Olivier
Post by Guest »
actual size to me is image pixel dimension size.
Eg in Photoshop and many other apps one can hit a button and get an actual size image (or a print size image). Actual size is also very usefull in making rapid appraisal to view sharpness, colour, contrast etc in view mode
As common with some other apps XnView gives many size options, the most obvious being 'fit window, fit width, fit height' etc but all under a drop down window. All I am suggesting is it possible to have a button to hit to obtain an actual size image, which I would argue is the most usefull size available, without going thro a drop down window.
If this is causing so many queeries I should perhaps withdraw the suggestion.
JohnL
Post by Guest »
Anonymous wrote:actual size to me is image pixel dimension size.
Try * and \
The asterisk key <*>. Its listed under the menu>zoom 100%. It looks like a place marker, but it isn't- its the keyboard shortcut.
The backslash key <\> to fit image to window.
Post by Guest »
I mean forward slash for fit to window /. Its under menu>view>autoimage size> fit window to image all </>.
Good luck JohnL.
