JPEG XL compression
Xn User
JPEG XL compression
Post by Xn User »
Hi )
Compressing a file to JPEG XL in Irfanview and in XnViewMP / XnConvert produces files with very different sizes.
In IrfanView, if I enable the option to Use modular mode, and set quality to 100% and set speed effort to 9, the output file size is 6 405 735 bytes.
But if I uncheck that option, the output file size is only 2 970 635 bytes, could you support this option in XnView software please?
