Folder thumbnail size
FrostWolf
Post by FrostWolf »
I set the thumbnail size to 384 x 288 and it works for images but not for folder thumbnails.
Is it possible to make it work so it resizes folder thumbnails too?
If not, then I would like to place a feature request to implement that
Thanks
This is how it shows the folder thumbs:
For image thumbs (inside folders) it works:
FrostWolf
Re: Folder thumbnail size
Post by FrostWolf »
I found it:
Tools -> Settings -> Browser -> Catalog -> Enable Catalog + Enable thumbnail caching + set Width, Height
FrostWolf wrote: Fri Jul 22, 2022 9:12 am I found it:
Good that you've found the appropriate setting and could solve your problem yourself, FrostWolf.
