Hi I'm pretty sure this is either a feature or my inexperience (PEBCAK)
Sometimes when I want to select say a 16:9 ratio box the 'box' seems to flip round to be 9:16 as though it was confused as to whether i was in portrait or horizontal mode
Edit>Selection Ratio: Selection sometimes horizontal sometimes vertical?
zzapper
Re: Edit: Selection Ratio box sometimes horizontal sometimes vertical?!?
do you have a way to reproduce?
zzapper
Pierre
Prochain fois que c' arrivera
David (Je suis très chaud pres de Bordeaux!)
zzapper
Thank you for providing a screenshot, David. When setting selection ratio (e.g. 16:9), XnView will set the selection depending on the orientation of the image - either portrait (16:9) or landscape (9:16). This adaption was built into XnView Classic (and now in XnView MP) is on purpose to support the user. With "Edit > Swap selection width / height" or "W" key you can swap the orientation.
BTW: In XnView Classic the shortcut for "Selection - Swap width & height" was "Tab" which easy to remember and somehow intuitive. Why has this shortcut been changed from "Tab" to "W" in XnView MP?
Related topics:
- Suggestion for Selection Ratio
Related topics:
zzapper
Thanks Helmut the workaround is great just type 'w' .
it was only a little problem but how can I put it bothered me quite a bit
Thank you for your feedback, zzapper. Good to read that I could help a bit.zzapper wrote: Sun Aug 07, 2022 6:15 pm Thanks Helmut the workaround is great just type 'w' .
