“DropShadow” crashes
Locked
:) Hello All !
- Open a very small picture in "View", especially a 32 BPP BMP 16*16 pixels -the display being set @ 32 BPP-
- Filter menu >> Effects >> DropShadow
- Tick the box “Keep original size
- XnView crashes, I get the beloved M$' message and the programme is closed. Error address : Offset 000D4970
- This occurs also with other types and 16 BPP at display, but harder to reproduce (needs to play with the adjustement cursors too) for small images.
- I noticed that the default values when opening are :
—> Radius "0"
—> Depth "6"
with such a small pic, "6" seems too much…
- I can reproduce that crash at will.
:mrgreen: K R
Xyzzy
Post by Xyzzy »
Confirmed.
b2.
Used Clo's image.
It is enough to move Radius slider a few times to generate crash.
32bpp Desktop.
X.
Thanks---
:) Hello L. !
¤ Thank you to check that :bugconfirmed:
¤ It's a bit random to get it, following the pics and the machines too I guess…
:mrgreen: KR
marsh
Post by marsh »
Me too. (both reports). Also in v.1.8
When either radius or drop shadow depth setting is too high for small image, crash occurs.
marsh wrote:Me too. (both reports). Also in v.1.8
Right, can be used on small picture
Can or cannot ?
;) Hi!
- Do you mean rather cannot be used with small pics ?
- Which minimal size is required ? That might be defined, I guess…
:mrgreen: KR
ckit
Post by ckit »
Fixed in Beta 3.
No crash, but---
:) Hi !
- No longer crashes in ß-3, but the function doesn't work for small images (the same than the link in the start-message).
:arrow: Pierre
Please, could you say if this is definitely impossible to get ?
:mrgreen: Kind regards,
Locked
