MicrosoftPhoto: deleting [XMP:XMP-microsoft] with XnViewMP?
Gerald_Ire
Post by Gerald_Ire »
Some problems with subject-xmp in MicrosoftPhoto got meantioned already in the forum!
We tried to delete XMP or [XMP:XMP-microsoft] from the image with the option in XnViewMP 1.00 (April 2022)
It failed!
A quick solution for admins was with ExifTool: exiftool.exe -all= --exif:all --iptc:all *.jpg
This deletes all XMP and keeps Exif and IPTC, ​but this is not posible for general user.
Q./S.:Is there an easy option to do so for "general Users"?
:D Gerald says thx to all! :D
Re: MicrosoftPhoto: deleting [XMP:XMP-microsoft] with XnViewMP?
Post by michel038 »
Do you want to delete all xmp tags ?
Did you try Tools>Metadata>Clean> (select xmp checkbox) ?
Gerald_Ire
Oh, that's brilliant! Thanks "michel038". Didnt know about this option... :shock:
That is a very quick way to get all XMP (or other parts) deleted! IF they do problems to read files...!
Q.: one metadata part that makes mostly problems with there content or structure are: "iptc keywords 025" / "xmp subjects"
Would it be nice to add this options under XMP/subjects and IPTC-IIM/keywords incl the MicrosoftPhoto stuff... ;-)
Gerald_Ire
... something like this:
