Linux: Disable trackpad/mouse image file navigation
rahlquist
Post by rahlquist »
Long time user (since the late 90's with nconvert).
I am currently using
XnView MP Linux
Version 1.0 64bits (Apr 29 2022)
Libformat version 7.110
I find when I try to select an area to crop or copy in and image I have opened, under Manjaro linux it is far to easy to instead wind up scrolling through through the directory instead of doing a selection box. Is there a way to disable the ability of the trackpad/mouse to navigate up/down through the files in the directory?
Thanks!
Re: Linux: Disable trackpad/mouse image file navigation
when doing a selection box in the thumbnail view, the view scroll right?
