I find the feature "Show files in subfolders" very useful but I can't find a find way to keep this switch on all the time. Every time restart XNView this this is switched off again.
Is this an intended behavior or didn't I find the right place to change this behavior? Is there an attribute in the xnview.ini that I can change manually?
Another question: I use the "Batch convert" feature to generate a border for my photos on Flickr. I foundd that for the action "Border" the frame width can set to a maximum of 99. I have to use 2 "Border" actions to achive a border wider the 99. Can this limit be changed somehow or is this a enhancement request???
Thanks a lot and best regards
Ludger
Re: Show files in subfolders
Yes, it's the current behavior...LuNik wrote: Thu Aug 04, 2022 8:48 am Is this an intended behavior or didn't I find the right place to change this behavior? Is there an attribute in the xnview.ini that I can change manually?
ok, i'll change itAnother question: I use the "Batch convert" feature to generate a border for my photos on Flickr. I foundd that for the action "Border" the frame width can set to a maximum of 99. I have to use 2 "Border" actions to achive a border wider the 99. Can this limit be changed somehow or is this a enhancement request???
LuNik
Bonjour Pierre,
thanks for your quick reply and thanks for changing the limit for the border width.
Could you please consider to add a possiblity to save the setting for "Show in subfolders" in one of the next releases?! At least for me this would bring a big advancement for the ease of use.
Merci beaucoup
Ludger
Merci beaucoup
Ludger
