Filter >> Effects crashes XnView
Locked
:) Hello All !
- This problem could be related to this confirmed bug reported on the "New / Open" section for the 1.84 ß-2.
- Now, in the normal version 1.80.3, as soon as I ask for Filter menu >> Effects, XnView crashes immediately, and this at will for each try.
- I think that something is broken in the Win-GUI items since yesterday -when I found out the bug in ß-2-, because before all worked fine in the current version about the effects, I used several of them normally. :(
:mrgreen: Kind regards,
ouistiti
Post by ouistiti »
Confirmed, same here too :(
Paul
1,77245385090552...
ouistiti wrote:Confirmed, same here too :(
Paul
I can't confirm it, try to remove in xnvienw.ini [Process] Last=?
Crash still if testing again
:) Hello !
- No longer crashes when removing the flag of this entry.
- However, there is a snag here, since this should come back if I test again the DropShadow and it'ld cause a crash…
- IMHO, the faulty settings causing the crash might not be saved, while obviously they are currently…
- Just try to use "DropShadow" in the ß-2, then here, close and restart the 1.80.3 and ask again for "Effects"…
:mrgreen: KR
Locked
