I would like to be able to customize this menu so that other formats can be selected there, and not just the four that the author of the program considered relevant.
When you need to convert literally one image, it is not convenient to open a batch conversion and set the necessary settings.
Ability to customize the "Convert into" menu
MARK2580
Re: Ability to customize the "Convert into" menu
+1
A good suggestion, MARK2580. The "<Context menu> > Convert into" could have a submenu with all formats. And most recently used formats could become part of the "Convert into" menu - perhaps even including some options like quality for JPG format.
E.g.
E.g.
Convert into > JPEG (90% quality)
JPEG (30% quality)
PNG
_____________________
Format...
