Unnecessary and unintended differences (compared to XnView Classic)
XnView MP 1.0 is out and there are still quite a number of differences between XnView MP and XnView Classic. From my point of view, XnView MP and XnView Classic are supposed to be twins and look and feel as similar as possible. Some differences are necessary and good improvements and cannot be undone. But there's still potential for changes to make XnView Classic and XnView MP more alike. Some examples for unintended and unnecessary differences:
• Different order of menu items
• Different shortcuts
• Different labels/translation
Please feel encouraged to post here if you find a difference that you think is unnecessary and unintended and can be changed with little effort. Missing features are discussed and can be reported in topic List of missing features (compared to XnView Classic)
List of unnecessary differences (compared to XnView Classic): XnView MP 1.00 Last update: 07 August 2022
Reported / Open
• Order of menu items "Selection ratio" and "Selection size" (see Helmut's post)
• Shortcut in XnView Classic and XnView MP differs. (see Helmut's post)
Resolved
Re: List of unnecessary differences (compared to XnView Classic)
XnView Classic:
Edit >
Set Selection ratio
Set Selection size
XnView MP:
Edit >
Set Selection size
Set Selection ratio
Suggestion:
Order of menu items "Set selection size" and "Set selection ratio" should be swapped in XnView MP.
Edit > Selection - Swap width & height:
XnView Classic: "Tab" key
XnView MP: "W" key
Perhaps there is a good reason why shortcut has been changed - if not this should be corrected to "Tab" key in XnView MP.
Stock
Re: Unnecessary and unintended differences (compared to XnView Classic)
Post by Stock »
MP toolbar & infobar waste more vertical space than Classic
https://forum.xnview.com/viewtopic.php?&t=44655
I'd argue that the toolbars should be as slim as possible to show as much as you can of teh picture and avoid unnecessary scaling.
No matter how good the scaling algorithm, a picture always looks best at 100% zoom level.
Stock wrote: Wed Jan 18, 2023 8:21 pm MP toolbar & infobar waste more vertical space than Classic
I'd argue that the toolbars should be as slim as possible to avoid unnecessary scaling and show as much of the picture as possible.
toolbar has same height as Classic, and you can configure small toolbar
Stock
Post by Stock »
For the side-by-side comparison I used the small symbols:
