1.0 Batch convert>Actions: Positioning works wrong
ikyquocked
Post by ikyquocked »
XnView: MP 1.0 64 bit
OS: Windows 7 64bit
In the actions window buttons for position changing (up/down) are working wrong.
The up button replaces an action downward, and the down button does it upward.
https://prnt.sc/V9AjssmAGlxv
https://prnt.sc/Yi_tWNDK1RYr
1. Open Batch Convert > Actions
2. Add three actions
3. Try to move middle action upside pressing "up" button
4. It moves downside
Actual behaviour (bug): "Up" button moves the action down :bug:
Expected behaviour: "Up" button will move the action upside
Re: 1.0 Batch convert>Actions: Positioning works wrong
Thank you for your bug report with screenshots, ikyquocked. Man, that's quite a number of actions that you use in Batch convert!
I've just tried to reproduce the problem and added the same actions as in your screenshot. Then I saw a significant difference between your screenshot and my dialog: In your screenshot buttons/symbols of up/down buttons are swapped: Down is on the left side and up is on the right side. And it seems up/down functions aren't swapped and thus you press a button and the appropriate action is moved in the wrong direction.
I have no idea why symbols (or buttons) are swapped - has anyone a guess? And I'm not sure how to get this problem fixed - perhaps by reinstalling XnView MP.
PS: Just noticed that reordering actions using drag & drop is also possible. 8) But sure enough up/down button should work properly, too.
ok, right a bug on High DPI screen
xnview wrote: Thu Aug 11, 2022 11:55 am ok, right a bug on High DPI screen
Thank you for your checking and confirming the bug, Pierre. :bugconfirmed:
