1.0 CR2 info block in view mode
ikyquocked
Post by ikyquocked »
XnView: MP 1.0 64 bit
OS: Windows 7 64bit
XnView sometimes doesnt shows infomation block in the view mode for CR2 files.
It is appears 50/50, one time yes, second time no, third time yes, then no... etc
1. Open cr2 file from the browser mode
2. Info block appears
3. Close
4. Open the same file again
5. It doesnt appears
Actual behaviour (bug): Info block appears for 50% times :bug:
Expected behaviour: Info block will appear always
Re: 1.0 CR2 info block in view mode
Thank you for your bug report, ikyquocked. I could reproduce your problem: :bugconfirmed: Once set visible, image info should appear for all images until image is hidden by user. But when opening a CR2 file and then a JPG file, the image info is no longer displayed. Please note that image must be opened using a double-click to reproduce the problem. When using "Open" in context menu or Ctrl+O shortcut the problem won't occur.
