Hello, is it possible to add tiff 16 bits per channel saving option ?
Im working with 16 bit tiff scans oftenly and I noticed XnView processing them into 8 bit RGB always and no option to choose. Also looks like XnCovert works in the same way...(
Indeed, It's old suggestion or I cant find out how to convert it in the right way (Im using batch and actions).
TIFF 16 bit saving
Re: TIFF 16 bit saving
currently only NConvert can process in 16bits
