Outline and Opacity also for Fullscreen/Slideshow
Dreamer
Post by Dreamer »
Just another try...
Link to original topic - Outline and Opacity also for Fullscreen/Slideshow
Original topic text:
Add border / outline and opacity also to Fullscreen and Slideshow Information text.
This feature is already in xnview, so I think it could be easy to "add". It would be very nice to have it also there (for everyday use).
Black background is not nice and without background is the text often unreadable...
Also custom colour for the text would be nice.
XnView 1.82 <x>
Re: Outline and Opacity also for Fullscreen/Slideshow
Dreamer wrote:Just another try...
Ok, but in thie version :-)
Dreamer
Post by Dreamer »
xnview wrote:Ok, but in thie version :-)
Sorry, I don't understand. :?
Sorry :-)) 'Ok, but not in this version', i have a problem with my fingers
VuDu
Post by VuDu »
http://newsgroup.xnview.com/viewtopic.php?p=16045#16045
|VooDoo| wrote: - Could it be added a shadow/glow/stroke/(whatever...) effect to the Information because the opaque background covers a lot of important Image space. It should work like movies' subtitles with transparent background or simple shadow, outer glow or small stroke.
that sure would come handy ;)
Ad decus et ad libertatem nati sumus
Aut haec teneamus aut cum dignitate moriamur
Dreamer
Post by Dreamer »
|VooDoo| wrote:http://newsgroup.xnview.com/viewtopic.php?p=16045#16045
Thanks for your support, but this topic is just for beta and possibly will be deleted...
Please add your support to original topic, thanks.
Dreamer
Post by Dreamer »
Pierre, just one more question - what about "custom colour for the text" only, in this version? It should be easy to implement, I'd like to have just all standard (RGB) colours, the same as for background. Now I can choose just 16 colors. If not possible, never mind.
Xyzzy
Post by Xyzzy »
Pierre, can this last feature make it into 1.82 or Postponed?
X.
Xyzzy wrote:Pierre, can this last feature make it into 1.82 or Postponed?
Postponed please
