1.00: Toolbar not shown
XnView: MP 1.00 - 64 bit
OS: Windows 10 64bit
Toolbar is no longer shown
Effect: In all modes (browser mode, image view mode) the main toolbar with all its symbols is not visible and thus cannot be used.
I have no idea how this happened. When showing / hiding the toolbar using "View > Toolbar" menu there is some change in the user interface but the toolbar doesn't become visible. To me it looks as if for some reason the vertical size of the toolbar is wrong. I've deleted xnview.ini but this didn't help.
Where is setting for vertical size of toolbar stored? Any idea how I can get this fixed, again?
Re: 1.00: Toolbar not shown
By deleting configuration file "default.bar" I could solve the problem (folder with XnView's configuration files can be opened by starting XnView and using "Tools > Settings | Integration | Paths| Open Config Files Location").
I still wonder why and how this happened. I've saved the buggy "default.bar" - please let me know if you want to have it to track down the problem, Pierre.
yes please send me the default.bar
xnview wrote: Sat Aug 13, 2022 12:28 pm yes please send me the default.bar
I've just sent file "default.bar" to you. It's empty (0 bytes in size). My hard disk is almost full - maybe the problem is related to that.
