Allow Userprofile Variable in Startup location
HEJUBA
Post by HEJUBA »
We would like to add the user profile folder as startup view:
However, it appears that the system variable %userprofile% isn't handled properly by XnViewMP.
We would like to use it with this parameter, to use the ini file for deployment reasons and for the use on an terminal servr.
HEJUBA
Re: Allow Userprofile Variable in Startup location
Post by HEJUBA »
Any recommendations on this? We use xnviewmp on a terminal server and each user should get their own user folder.
For that we need the default windows system variables
Is that possible or already on on the wish/bug list?
Thanks a lot for your feedback
Thank you for your request, HEJUBA, and sorry for not replying earlier. Perhaps Pierre, the author of XnView, could add support for system variables whenever specifying directories but I guess this won't happen within few days.
Could you perhaps distribute XnView MP with a personalized xnview.ini file included? The xnview.ini file would consist of following settings, only:
[Start]
startupType=2
customPath=<Content of variable %USERPROFILE%>
HEJUBA
Post by HEJUBA »
Hi helmut,
Thanks for your feedback.
We`ve tried already with a custom ini file. Unfortunately without success.
I`ve tried it again with your recommendation. Nothing happend.
I think the app is not able to resolve the variable as you can see in the screen.
@Pierre: Could support for a selected environmental variable be easily added, or could it be difficult or for practical purposes impossible :?:
