Hi!
Since version 1.01 I cant open te system context menu (with control + right-click mouse) when I have selected several files.
In that case, all files are deselected and only the file on which the mouse is positioned remains selected.
Finally the system context menu opens, but only applied on that single file.
Thanks
Access to system context menu (mouse right-click menu) doesnt work
aticus
Scargoth
Re: Access to system context menu (mouse right-click menu) doesnt work
Thanks, I never sawn we can do it
for info : It still works on my machine with 1.01
Regards
Regards
aticus
Thanks for your attention.
I have more information
If I control + right click on the last selected file, then it works fine: the system menu opens with all selected files.
Any other option deselects all other files that the mouse is not hovering over. Rare.
Scargoth
Oh, Yes,
it's same on my desk.
I allways made the Ctrl+Right-Click on the last selected file (it was so natural ^^)
I confirm, when I Ctrl+Right-Click on any other selected file; only this file stay selected.
Scargoth
FYI
I tested on an other machine with 1.0 64bits (Apr 28 2022) : The comportement is the same
I can't reproduce, i select 3 files, and mouse right click open the system context menu. On win 10?
aticus
Maybe when you click the mouse, the cursor was on the last selected file? If so, I also get the system menu. The problem is when it is on another selected file. I am on Windows 10
Thanks and great program!
Scargoth
Je confirme :
je ne me suis pas rendu compte du problème / ai cru ne pas le reproduire
en lisant le message de Aticus, tellement il est naturel de faire le clic droit sur le dernier fichier sélectionné...
mais si je "fais attention" à faire le Ctrl clic droit sur n'importe quel autre fichier sélectionné, je n'ai effectivement le menu contextuel Windows que pour le fichier cliqué.
ceci-dit, ce n'est peut-être pas le cas pour toutes les machines.
I confirm:
I did not realize the problem / thought I did not reproduce it
when I read Aticus' message, so natural is it to right-click on the last selected file...
but if I "pay attention" to do the Ctrl right click on any other selected file, I have indeed the Windows context menu only for the clicked file.
this being said, this may not be the case for all machines.
I confirm:
no i have selected 2 files at top
