"Not enough Memory" error opening tif
nanuk2
I was trying to open a 118MB multi-page tif file (15 pages) when I got the error above. The image was a 1641 x 2115 in 24bit color. The odd thing was, I opened up a similiar document just this morning that worked fine. I'm sorry, but I can't send the image, as it contains confidential info.
Re: "Not enough Memory" error opening tif
You can open similar picture with same dimension??nanuk2 wrote:I was trying to open a 118MB multi-page tif file (15 pages) when I got the error above. The image was a 1641 x 2115 in 24bit color. The odd thing was, I opened up a similiar document just this morning that worked fine. I'm sorry, but I can't send the image, as it contains confidential info.
Drahken
You could PM the error info to xnview nd/or edit out the personal info.
Was the other image also 118megs? Perhaps it was slightly smaller, just small enough to squeeze in under the available memory? Also, were you running any other programs at the same time that you got the error, anything that might have been eating up some of your memory?
