MacOS: Thumbs and full size not synched
brucet99
Post by brucet99 »
Subject: 0.99.7: thumbnails and full-size images not synched.
XnView MP MacOSX Version 1.02 64bits (Aug 24 2022)
OS: Mac 12.5.1 Monterey / 64bit
Effect: Select a thumbnail and click to open as full-sized image, then advance through several images, return to thumbnail view. Original thumbnail is highlighted instead of the one corresponding to the last-viewed full-size image.
1. Highlight a thumbnail image.
2. click to switch to full-size view.
3. Using right/left menu bar arrows or arrow keys, step through viewing several full-sized images, either forward or backward.
4. press "esc" key to return to thumbnail view.
Expectation is to see the last viewed image's thumbnail.
Actual behaviour (bug): First image thumbnail is still highlighted instead of thumbnail from last viewed full-sized image.
Another user (Windows version) on the Forum said to go to "Tools>Settings" and click "synchronize" to solve the problem. There is no "Settings" to be found under Tools or any other menu that I could find.
Re: bug report thumbs and full size not synched
do you have settings>Interface>Synchronize browser...?
brucet99
Post by brucet99 »
I haven't found "settings" anywhere. Where am I supposed to be looking?
in the menu, or button in toolbar
brucet99
Re: MacOS: Thumbs and full size not synched
Post by brucet99 »
Thanks. That got it.
