Subject: 0.99.7: Wrong keyboard shortcuts
XnView: MP 1.02 /64 bit
OS: Mac / OS 12.5.1 /64bit
Windows keyboard shortcuts are listed instead of Mac versions; CTRL key instead of Command, Meta and Alt keys that do not exist in Mac
Effect: none of them work
1. Settings
2. Shortcuts
Bug report keyboard shortcuts
Re: Bug report keyboard shortcuts
CTRL is shown but Command is used, shortcut doesn't work?
brucet99
Of course Command works, but CTRL is what the list tells me to use, so it shouldn't appear that way in a mac version.
And I have no idea what I would use in place of Meta and Alt.
