if you copy image from one directory to another, and there are duplettes, xnview can rename the files to avoid double filenames.
but if you enter a name which is already there, XNview makes no error message
e.g. you can name all files
as4
there is no complain about that
							beta2 bug: renaming double files
XNView 1.91.5
Windows XP SP3
						Windows XP SP3
Re: beta2 bug: renaming double files
How can i reproduce it?klumy wrote:if you copy image from one directory to another, and there are duplettes, xnview can rename the files to avoid double filenames.
						e.g:
directory 1:
Directory 2:
I want to moce all files from directory 1 to 2
now xnview popup says double file, do you want to rename
xnview proceeds to the next image test2.jpg without saysing that in directory 2 is already a file named test2.jpg
							directory 1:
Directory 2:
XNView 1.91.5
Windows XP SP3
						Windows XP SP3
