Shortcuts that use the numeric keypad, aren't working
desbest
Post by desbest »
Pressing the numerical keys on the numeric keypad, doesn't execute the shortcuts that it should, when in viewer mode.
  1. Open an image in viewer mode. It should appear in a new tab
  2. Press the 1 or 3 keys on your numeric keypad. Be sure that num lock is turned on instead of off, so that it won't scroll up and down.
Actual behaviour (bug): Nothing happens. The zoom of the image doesn't change.
Expected behaviour: The shortcut should work
I'm using Windows 10 21H2 and xnView MP 1.3
Both my windows installation and xnView is 64 bit
Re: Shortcuts that use the numeric keypad, aren't working
these shortcuts are for Classic not MP, you can change them in Settings>Interface>Shortcuts
