Saving any configuration is a pain
faltonico
Post by faltonico »
Hi!
Is there a way to make the viewer to save ANY sort of configuration without having to launch the app in administrator mode, or writing to the registry? (i avoid using the registry cause it gets littered with keys that don't get deleted on update/removal). Or is it that i somehow screwed my installation?
It is kind of annoying to have to do that even for it to remember the window position.
Thank you very much in advance for any help!
Re: Saving any configuration is a pain
Post by michel038 »
With Windows OS ?
I use a portable zip version of XnViewMP , unzip it into a folder not locked by Windows, and set the location of the configuration files in the same folder.
(Tools>Settings>Intergation>Paths)
Never had problems with saving configurations.
I often backup copies of some configuration files (recently modified files) in a folder that I have added in my xnviewmp folder,
faltonico
Post by faltonico »
michel038 wrote: Sat Sep 10, 2022 1:09 pm With Windows OS ?
Yeah, win 10 Pro.
I install the program, I am not using it as a portable app, will just installing it some place else other than "program files" would resolve this?
EDIT: omg why did i say win 11? it is not.
where do you save the settings?
faltonico
Post by faltonico »
xnview wrote: Tue Sep 13, 2022 5:58 am where do you save the settings?
@C:\Users\USERNAME\AppData\Roaming\XnViewMP
Windows 10 Pro 21H2.
I have these files in there:
it's correct, and your settings are not saved between session in your user account?
faltonico
Post by faltonico »
Nope, i have to start the program as an administrator even if i want to change the window position.
faltonico wrote: Fri Sep 16, 2022 11:32 am Nope, i have to start the program as an administrator even if i want to change the window position.
try to remove Roaming\XnViewMP and start from your user account
faltonico
Post by faltonico »
xnview wrote: Fri Sep 16, 2022 2:49 pm and start from your user account
I just did, and nothing i do on the settings get saved every time i open the program.
If i save in the registry will it remember the settings?
I even have less files in the folder now.
no files in Roaming\XnViewMP are created?
faltonico
Post by faltonico »
xnview wrote: Mon Sep 19, 2022 12:03 pm no files in Roaming\XnViewMP are created?
Sorry for the late reply.
Yes, there are no config files now, only the .db:
you have not a xnview.ini in the program folder?
faltonico
Post by faltonico »
xnview wrote: Tue Sep 20, 2022 5:50 pm you have not a xnview.ini in the program folder?
Yes, it is there.
How do i move it from there?
EDIT: I just found the option, it is in "integration - paths"
EDIT2: Replaced the .ini in the roaming folder with the one in the program files to keep my settings. Now all of the changes i do, persists.
Thank you for your help!.
But seriously, that should be the default option instead of the program folder.
faltonico wrote: Wed Sep 21, 2022 4:42 pm But seriously, that should be the default option instead of the program folder.
Program folder is not the default option
faltonico
Post by faltonico »
I have no clue when i selected that, a long time ago i used the registry and i regretted it, so maybe i chose that as an alternative and didn't pay much attention to what it implied. This behavior is not new... i have had this since a long time ago, i just got tired of it very recently.
Thanks again for all your work!
