I have a fresh install of XnViewMP 64-bit, Win 10 21H2 (19044.1889).
- some numbers are displayed in non-expected (and not really readable) font:
- the same happens with some boxes in Settings:
- no other application does this (this applies to XnView Classic, displaying everything just right)
- I have tried changing fonts via Settings, via theme css file, reinstalling, running non-installed version extracted from zip file, turning off font-manager, everything I could come up with short of reinstalling Windows...
...which leads to a question: what font should display that data? Maybe I have uninstalled some fonts that are necessary for XnView MP?
My regional settings (just in case):
Thanks!
Wrong label fonts - help anyone?
bc_is_too_short
Re: Wrong label fonts - help anyone?
Settings>General - Language is on English?
bc_is_too_short
English (en) to be precise, although no matter what is set there, the problem persists
with old version you had no problem?
Did you try another font ? Maybe MS Shell Dlg2 (shown in your screenshot) is damaged ?
Catalogage avec XnviewMP :
bc_is_too_short
I had no problem with an old version and I also checked different font in case of file being corrupt.
I managed to fix it finally, though I have no idea what was broken.
Control Panel > Region > Additional Settings and I reset settings to defaults, reverted to my settings and all looks good.
Looks like Windows fault. What baffles me is - why XnView MP was the only program affected and only partially?
Thank you for all the help.
