How to conserve the size of the file convert from tif to ppm
yarrow
Post by yarrow »
Hi, All,
I use nconvert to convert tif files to ppm. The size of my tif files are about
25M each. When i convert it to ppm, It becomes 75M each. The command
i use is:
nconvert -in tiff -ctype grey -colors 256 -out ppm -truecolors 1.tif
I wander is there any way to preserve the size of the tif file. I want 25M
ppm, not 75M. It is too big.
Thanks
Re: How to conserve the size of the file convert from tif to
yarrow wrote:Hi, All,
i use is:
PPM is uncompressed format, so it's not possible
Post by Guest »
i use is:
Yes, i see. But the thing is that my tif file is also not compressed. I checked the property of the tif file and the converted ppm in xnview. I saw that the tif uses 1 byte for each pixel, while ppm uses 3 bytes for each pixel. So my question is whether it is possible to have a ppm using 1 byte each pixel? or every ppm should use 3 bytes for each pixel?
Thank you
i use is:
Thank you
PPM is only in RGB mode
