1.3 - UI - RIOT menu option enabled when addon is not installed
XnView: MP 1.3.0 64bits (Sep 6 2022)
OS: Windows 64bit (21H1)
"RIOT" menu option enabled when addon is not installed / located in XnView's AddOn folder.
Effect:
UI only.
1. download XnViewMP archive, extract and run program
2. goto Tools -> RIOT.. option enabled
3. press it - nothing happens
Expected behaviour:
RIOT menu option shall to be disabled (gray) if no RIOT AddOn in Addon folder.
Suggestion:
Maybe worth to show message that user has to install RIOT manually and link to it's website.
Re: 1.3 BUG - RIOT addon missing in .zip archive
yes you need to install it, but the entry must be greyed if riot is not here
Got it, thanks. Initial post updated.
you need to install from https://riot-optimizer.com/download/
I understand and absolutely OK with that.
However this bugreport is about XnViewMP UI.
I do not have RIOT installed on my pc and, in my understanding, RIOT.. menu option shall be disabled (gray) for me.
