EXIF data in PNG files
Post by michel038 »
Pierre,
Can you implement exif data for PNG files ?
At least create date , date/time original and modify date ?
So we will be able to sort photos by exif date in the browser ...
Test :
- Select a PNG file.
Change timestamp
Check "Create EXIF if needed"
Check 3 exif boxes
Write
What is shown in Information pane :
"ExifTool" tab : Exif data shown
"Exif" pane : Empty
Suggestion : display (and use) some EXIF data in XnviewMP
Notes
"Properties" tab is unchanged (I'm not talking about file system dates)
"ExifTool" tab shows also PNG create date and PNG modify date. I don't care about these dates that ExifTool has updated.
