Hotkey for Screengrab. Self defined?
iorx
Post by iorx »
It would be awesome if one could pick a shutcut combination ourself.
I've seen other apps where you hold down the combination you want and it picks it up. Wouldn't that be a more pleasant solution then the list it got now?
Happy coding! :D
Re: Hotkey for Screengrab. Self defined?
In the browser there is Tools > Capture... which is at least close to what you need?
