1.3.0 on Windows 10
Guys - if I open an image from a folder, it opens full screen in XnView. After that, if I hit Esc or do Alt+F4, I would like the program to close completely but it simply opens the browser. Is there a setting to change the behavior? I can't find one
Thanks
Alt+F4 to exit XnView
Re: Alt+F4 to close
That is what you want? If not, that can be changed in Tools > Settings > General -- General tab.dohat34 wrote: Wed Sep 28, 2022 11:55 am 1.3.0 on Windows 10
That option is available in Tools > Settings > Interface -- Keyboard tab...After that, if I hit Esc or do Alt+F4, I would like the program to close completely but it simply opens the browser. Is there a setting to change the behavior?
