Hi team,
There was a "gamma" parameter in the "print window" (July 2022), and it is no longer there... Is this intentional?
Regards
Print dialog Gamma setting
Woo
Re: Gamma parameters
was not used
Woo
How can I recover it?
I will have to go back to Acdsee because of this very useful feature, which admittedly not many people know about
Old versionsWoo wrote: Sat Oct 29, 2022 3:52 pm How can I recover it?
But if you have to go back a long way, the last XnView MP version which supported gamma may be much less functional...
But you could probably use the current version normally, and also use a version which supported gamma for printing using a portable version.
but it was the same in old version
