Export of Multiple image
TorrediPisa
Post by TorrediPisa »
Good Day
Is it possible to resize (Export) multiple images? (having set the percentage)
instead of processing one by one.
Thanks a loto for yr assistance.
Fabio
Re: Export of Multiple image
TorrediPisa wrote: Sun Oct 02, 2022 5:17 pm Is it possible to resize (Export) multiple images? (having set the percentage)
I think you need Tools > Batch convert... :D
TorrediPisa
Hi
Thanks for yr prompt reply.
In the Tools/Batch Convert I cannot find The Export action...
Have you an idea about what command I should activate to do that task?
Thanks again
Fabio
TorrediPisa wrote: Mon Oct 03, 2022 9:25 am In the Tools/Batch Convert I cannot find The Export action...
By Export you mean save?
TorrediPisa
That'all right!
Understood!!
Thank youi very much for yr prompt help!!!
