1.3.0 - view - scaling - transparency grid issue
XnViewMP 1.3.0-1.9.8
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Viewer/Browser - transparency grid
transparency grid scaling issue
to reproduce
0. prerequisites
  • set win dpi scaling to 150%
  • change Transparency grid color/size (yellow-pink/25px) to make more noticeable (in Settings>View)
  • have test images w transparency (100x100px, 4 and 32bit)
    test_img_transparency_grid.zip
Issue A1 - fixed in 199
1. open test image in Viewer, zoom 100%
Transparency grid will be ~37x38 (25x25px * 1.5)
expected
no need to scale transparency grid
Issue A2
2. turn off transparency
- for 4bit image - uncheck 'Use transparency index' (Ctrl+Alt+H)
- for 32bit image - uncheck 'Use alpha channel' (Ctrl+H)
transparency will turn off - OK
transparent grid will still be rendered (visible on the sides)
expected
when turning off transparency, maybe disable transparency grid as well, as its not supposed to be visible anyway
Issue B - image distortion1
image will be distorted
transparent grid will be visible on the right and bottom sides
expected
render w/o distortion, like the same image w/o transparency
to double check - remove transparency from image, save and reopen
image will be rendered w/o any distortion at 100x100px
Issue C - image distortion2
2. turn on transparency
3. repeat steps 2 and 3 (quickly for better visibility)
transparency will turn on/off - OK
image will shift (could be related to this shifting as zoom-out antialiasing filter applies at 0-149% range)
Example
  • Bridge
    thumbnails have similar problem of image-transparency grid alignment at certain sizes (any dpi) :D
Related
Re: 1.3 BUG - extra border in png RGBA
Is Zoom on HiDPI screen: 1 image pixel equals 1 screen pixel in Tools → Settings… → View → View activated, user0?
XnTriq wrote: Wed Oct 05, 2022 2:00 am Is Zoom on HiDPI screen: 1 image pixel equals 1 screen pixel in Tools → Settings… → View → View activated, user0?
Nope, it is not checked by default.
However, I can confirm that the issue is gone when this box is checked.
It's worth mentioning that the issue is gone if the alpha channel is removed from the png image.
Also no such issue in XnView Classic.
user0 wrote: Wed Oct 05, 2022 4:59 amHowever, I can confirm that the issue is gone when this box is checked.
I believe that this setting turns DPI awereness on and off.
