Hello, Great job with your software! Congratulations!
But what a deception, seeing that the Fav pane is just a list of locations and not something like a king of file explorer.
My wish is to have something like on the image below, that could be used to store roots of directories I am often using, that I could click on to enter the sub directories or alternatively that could reflect the real current directory (if entered through the image pane):
I noticed that if I switch to the Folder pane after selecting a Fav, I have the requested behavior, but anyway, if sometimes you feel in mood for that, I would really appreciate.
Many thanks,
Paxel
Behavior of Fav pane
Paxel
