[Resolved] 1.3.00 on Ubuntu 20.04.5 - XnView crashes when reading movie (mp4)
SpatMan
Post by SpatMan »
XnView: MP 1.3.00 - 64 bit
OS: Linux Ubuntu 20.04.5 - 64bit
Since I installed XnView MP 1.3.00, it crashes when selecting a movie thumbnail (mp4)
Was OK with 1.2.00
Effect: Program crashes
1. Launch XnView
2. Open a folder containing a .mp4 movie
3. XnView tries to start playing movie then crashes
Expected behaviour: No crash and movie playing in the "overview" window
Thanks for any advice, maybe my Linux installation is not correct
Here is a log when XnView launched from terminal:
### ThumbLoaderThread :: setFirstItemToLoad
** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
######ThumbLoaderThread :: forever 2 : 3809090
CHECK <1>
### START 408
######ThumbLoaderThread :: start : 1 0 -1
MyView::set LOAD FULL /media/spatman/*****/_30.mp4
BitmapLoadThread :: stop()
## MyView::onLoaded </media/spatman/*****/_30.mp4> </media/spatman/*****/_30.mp4> </media/spatman/*****/_30.mp4> (0)
## MyView::onLoaded ok
MyView::change /media/spatman/*****/_30.mp4
OPEN player /media/spatman/*****/_30.mp4
######ThumbLoaderThread :: forever : 3809090
** start condition wait
QMDKWidget setMedia /media/spatman/*****/_30.mp4
QMDKWidget play
############################################ InfoPropertiesView
Create Tree : Fichier
VAImageFormat.fcc: 0x41524742 BGRA, lsb: 1, bpp: 32, depth: 32, mask: 65280,16711680,4278190080,255
VAImageFormat.fcc: 0x42475241 ARGB, lsb: 1, bpp: 32, depth: 32, mask: 16711680,65280,255,4278190080
VAImageFormat.fcc: 0x41424752 RGBA, lsb: 1, bpp: 32, depth: 32, mask: 4278190080,16711680,65280,255
VAImageFormat.fcc: 0x52474241 ABGR, lsb: 1, bpp: 32, depth: 32, mask: 255,65280,16711680,4278190080
VAImageFormat.fcc: 0x58524742 BGRX, lsb: 1, bpp: 32, depth: 24, mask: 65280,16711680,4278190080,0
VAImageFormat.fcc: 0x42475258 XRGB, lsb: 1, bpp: 32, depth: 24, mask: 16711680,65280,255,0
VAImageFormat.fcc: 0x58424752 RGBX, lsb: 1, bpp: 32, depth: 24, mask: 4278190080,16711680,65280,0
VAImageFormat.fcc: 0x52474258 XBGR, lsb: 1, bpp: 32, depth: 24, mask: 255,65280,16711680,0
VAImageFormat.fcc: 0x30335241 AR30, lsb: 1, bpp: 32, depth: 30, mask: 1072693248,1047552,1023,805306368
VAImageFormat.fcc: 0x30334241 AB30, lsb: 1, bpp: 32, depth: 30, mask: 1023,1047552,1072693248,805306368
VAImageFormat.fcc: 0x30335258 XR30, lsb: 1, bpp: 32, depth: 30, mask: 1072693248,1047552,1023,0
VAImageFormat.fcc: 0x30334258 XB30, lsb: 1, bpp: 32, depth: 30, mask: 1023,1047552,1072693248,0
VAImageFormat.fcc: 0x36314752 RG16, lsb: 1, bpp: 16, depth: 16, mask: 63488,2016,31,0
VAImageFormat.fcc: 0x50424752 RGBP, lsb: 1, bpp: 24, depth: 24, mask: 0,0,0,0
VAImageFormat.fcc: 0x50524742 BGRP, lsb: 1, bpp: 24, depth: 24, mask: 0,0,0,0
VAImageFormat.fcc: 0x56555941 AYUV, lsb: 1, bpp: 32, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x30303859 Y800, lsb: 1, bpp: 8, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x3231564e NV12, lsb: 1, bpp: 12, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x3132564e NV21, lsb: 1, bpp: 12, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x32595559 YUY2, lsb: 1, bpp: 16, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x59565955 UYVY, lsb: 1, bpp: 16, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x32315659 YV12, lsb: 1, bpp: 12, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x30323449 I420, lsb: 1, bpp: 12, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x50313134 411P, lsb: 1, bpp: 12, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x48323234 422H, lsb: 1, bpp: 16, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x56323234 422V, lsb: 1, bpp: 16, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x50343434 444P, lsb: 1, bpp: 24, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x33434d49 IMC3, lsb: 1, bpp: 16, depth: 0, mask: 0,0,0,0
VAImageFormat.fcc: 0x30313050 P010, lsb: 1, bpp: 24, depth: 0, mask: 0,0,0,0
Create Tree : Audio
resizeGL>>>>>dpr: 1.000000, logical dpi: (90.000000,90.000000), phy dpi: (91.841808,91.745819)
Create Tree : Audio
SORT the list...
STD::SORT... 6
STL::SORT... 0
SORT the list... 0
SORT the list... 0
### ThumbLoaderThread :: updateFileList
ThumbLoaderThread :: stop()
### ThumbLoaderThread :: updateFileList ok
sizeHints : 166
"QColor::setRed": invalid value -10
"QColor::setGreen": invalid value -10
"QColor::setBlue": invalid value -10
glXGetCurrentDisplay:0x3114990, display from param: 0x7f0d940c1680
Segmentation fault
Re: 1.3.00 on Ubuntu 20.04.5 - XnView crashes when reading movie (mp4)
could you send me the mp4?
try to use
export QT_XCB_GL_INTEGRATION=xcb_egl
SpatMan
Post by SpatMan »
xnview wrote: Thu Oct 06, 2022 3:48 pm try to use
Added in xnview.sh: it works now.
Thanks!
