Hello. I am trying XnView MP (version 1.3 64bits) and I have encountered a problem with text labels in toolbar. It's clear to me that if the tool doesn't have an icon (here Rotate based... and Fit image to...), the descriptive text is used...
When I set icon manually...
... e.g. to xnviewmp.exe, there is no change... (yes, I restarted XnView)
Is it bug or I'm doing something wrong? (I tried it in 'classic XnView' and there it worked.)
Text label in toolbar instead of the icon
mikroslavek
Re: Text label in toolbar instead of the icon
did you choose a png file?
mikroslavek
Aaaaaah, I did not. It offered...
... so I selected just exe file (xnviewmp.exe) for the test. Now when I tried transparent PNG (64x64), it works. ICO files don't seem to work either. Maybe it's confusing and could be changed. But... PNG works for me. THANK YOU!
BTW XnView is great program
