Batch rename
TrailQuest
Batch rename
Post by TrailQuest »
When using the Name template, I'm looking for a list of variables that can be used inside the {braces}. Specifically, what I'm looking for is to save a 4-digit number in the original files name to the new file name. Each file has a different number, and they are not necessarily in sequence. E.g., img4637.heic to 20221004_4637XnView.heic. I've seen that variable called "Original File Number" but that does not work in XnView.
Re: Batch rename
please try {Filename Number}
TrailQuest
Re: Batch rename
xnview wrote: Thu Oct 06, 2022 6:24 am please try {Filename Number}
Thank you for that. It works!
I'd still be interested in the list of variables that can be used in the {braces}.
