XnView: MP 1.3.0 - 64-bit
OS: Windows 11 - 64-bit
XnView does not show number of frames in status bar of preview pane. Opening GIF in new tab does.
1. run clean XnViewMP
2. open folder with GIF files
3. select GIF
Actual behaviour: GIF preview playing but does not show frames in status bar.
Expected behaviour: XnView should show frames in status bar of preview pane.
1.3: GIF frames in status bar not showing
Re: 1.3: GIF frames in status bar not showing
you means 'Frame ?/?'?
user1
yes, it's missing in preview.
you have it in edit mode
user1
Opening GIF in edit mode shows 'Frame ?/?' but not in preview mode. I use preview to check and sort GIF files but without 'Frame' i never know when a GIF will end.
