1.3.0 - viewer - crop panel - selection width/height issues
XnViewMP 1.3.0 64bit
Windows10 64bit (21H1), display resolution 3840x2160, win scaling 150%
Crop panel
Few issues with the way selection width/height works.
2. open test image
3. press SHIFT-X to open Crop panel
4. make selection with the following settings:
Issue A
5. press increase width (OR height) button (blue)
it will decrease height (red). Happens when selection rectangular bears against image side (right in this case).
Issue B
5. press increase width button (blue)
it will increase width (red) AND decrease height of actual selection rectangular
Issue C
5. manually type values that are higher than real image size
nothing prevents user from typing such values
Issue D
6. manually resize selection rectangle
program will crash
Expected behaviour:
a),b) it should not be allowed to increase width/height values (via buttons) that are higher than the image size.
c),d) it should not be allowed to manually enter/paste values that are higher than the image size.
Related
Re: 1.3 - BUG - crop panel - selection width/height issues
Re: 1.3.0 - crop panel - selection width/height issues
1.5.0b1
A - fixed
B - still remain
C - partilly fixed (selection position - still possible to enter 99999, selection size - fixed). Guess its not a big deal and can be ignored
D - still remain
user0 wrote: Sat Jun 17, 2023 8:56 am B - still remain
fixed in b2
D - still remain
how do you resize selection after enter 99999, the selection is no more visible??
150b2
B - fixed
D - fixed
xnview wrote: Tue Jun 20, 2023 1:10 pm
D - still remain
I start with existing selection, than enter 99999
selection turns into ~1x1, but its possible to resize/rotate it
however, app does NOT crash anymore
imho behaviour shall be the same as with Free ratio - once you enter oversize value, force change it to image max value
