Rotate - resize canvas - do not crop [Solved]
mrwul
Post by mrwul »
XnView has wonderful rotate feature!
One minor drawback - maybe there a solution for it?
When rotating it happens that parts are lost, the size of the canvas does not change so the full photo remains in place.
I am sure there is a solution, but I vainly searched for a solution.
Any advice?
Thanks.
Re: Rotate - resize canvas - do not crop
mrwul wrote: Fri Oct 07, 2022 9:09 am When rotating it happens that parts are lost, the size of the canvas does not change so the full photo remains in place.
Could you clarify what you mean, with screenshots or steps to reproduce?
mrwul
Post by mrwul »
Like this, see attachment
With XnView the canvas does not resize, some other tool the canvas resizes along and image is not 'cropped'.
As said, maybe it is some setting within XnView MP I don't know.
mrwul wrote: Fri Oct 07, 2022 10:40 am With XnView the canvas does not resize, some other tool the canvas resizes along and image is not image is not 'cropped'.
If you uncheck the 'Auto crop' option?
If that does give the result you need, could you post the result from XnView MP, and the result from one of the other softwares that does give the result you need.
mrwul
Post by mrwul »
Auto crop(?)
Ehm... where to find that?
mrwul wrote: Fri Oct 07, 2022 2:18 pm Auto crop(?)
In your image above, one of four check boxes in the second screenshot from the left...
mrwul
Post by mrwul »
Oops!
Sorry, I overlooked those options.
Thanks!
Actually I was looking in settings all the time, but didn't pay attention to those boxes above.
Ahum ...deep sigh...
Thanks again.
