hi
select files and rightclick copy or move .later fired copy to move to dialog.
Sincerely
drjs5x
Re: select files and rightclick copy or move .later fired copy to move to dialog.
could you describe your problem?
drjs5x
select files and right click copy or move. result copy or move dialog box.
i m sure that a bug....
Sincerely
Sincerely
'Copy' in context menu?
drjs5x
yes dear. i fixed. is two "kopyala" at tr languagethere . how i can find language editor?
you can review the language file here
